Robert started this thread in July 2017
July 2017 in Masonry
For my layout I’ve scratchbuild this farmhouse and it’s barn. Easy because it’s the edifice where I live and work in…
So here are some pictures of the building proces. Cardboard, clay, plaster, wood, sand and wood are the main components.
I’ll let the pictures speak for themselves.
And the roof
Thanks for watching ![]()
Robert
July 2017
this is great stuff. Nice to see some different modeling techniques.
July 2017
Great modelling.
July 2017
I know you guys are used to see wooden structures, but until I can begin with the sawmill, it’s STONE !!! ![]()
July 2017
Exceptionally well done…you have got the stone work nailed to perfection.
July 2017
Oh my! Thanks for the progression photos. Great model.
July 2017 71.32.47.238
Robert,
Can you please describe in some detail how you created the clay roof tiles? They are exquisite!
Thanks, Dave S. Tucson, AZ
July 2017
The entire thing is awesome! Some really great looking stone/stucco. And I concur: how did you do the mold for the tiles?
July 2017 92.188.52.150
As you can see on the photos, I started out by filing the shape of the tiles out of a piece of square iron bar I had in my workshop. 22 tile moulds, I got out of this.
Then it was just a matter of first, putting masking tape ( the yellow) the two sides of the iron. Then I sprayed a little WD40 on it to remove afterwards easier the castings.
Then I pourred dental plaster ( or resin plaster as you like) , which is harder the the ordenary plaster, into the mould. I let it harden overnight and the I filed, while the plaster was still in the mould, the hollow part of the tile.
The advantage of leaving it in the mould is that the latter would support the fragile tile from breaking . If you should do this whilst holding a tile with your fingers , it would.
No way of clamping such a shape. I used a file to sharpen chain saws because it had the perfect fit. Then you can easily, but still carefully, push the shaped tile out of the mould.
This is a very time consuming process, but the result is there. I had to do about a thousand tiles, so it became a daily ritual. In the morning a batch, and in the evening a second that could harden overnight.
I also put a little white woodglue in the mix, instead af all water. Makes it tougher.
Then after all the laying of the tiles , in two layers. One upside down and the second over the latter, they are placed like that, the colouring could start. Tamya paints, AK interactive pigments, alcohol. A bit like Brett does his stripwood.
The patination is also a long term process since I painted the tiles one by one to get a realistic variation in the whole. Same as the stripwood.
And as with all the builds you do, look at the reality. All of my home roofs are tiled with these Roman Tiles or ‘tuilles canal’ in french as the are called.
So, as you can see, the theory behind all this is quite simple. It just takes time .
But as modellers, we’re used to that , aren’t we… ![]()
July 2017
Robert,
Bonjour Monsieur,
Thanks you for explaining your process of making roof tiles. From your explanation it is very clear how to achieve the results you got. Time and patience seem to be basic parts of the recipe.
At the present time I am making stone blocks to scratch build walls for a small structure. After that I will start to make roof tiles.
Merci Monsieur,
Dave Sarther. Tucson, AZ
July 2017
Robert,
After looking back at the build of your house and barn a few times as well as your other introductory postings I am beginning to think you have an established background in military modeling. You are quite the accomplished modeler and I can see that I have lots to learn from you and many, many other modelers in this forum about building structures. Looking forward to more of your posts and a possible tutorial of how you do your stucco walls and “coin blocks” (corner stone blocks in a masonry wall).
Later, Dave Sarther Tucson, Arizona
July 2017 edited July 2017
Hi Dave, I am glad you like my builds. But it is not what you think. I only started modelling about five years ago. Building brass kits in the Zéro Metrique scale . Om. No military stuff at all. Then I needed a layout for this rolling stock, and that is what you see now. Sorry for the illusion…
I discovered Sierra West and ordered the Sawmill from Brett. But meanwhile, I wanted to share my previous builds with the forum. I’ll post some more later on on what you’ve asked.
