How to Refine PCB Sleeper Appearance for Realism
Greetings, everyone. This shall not be a grand treatise, yet perhaps some among you share a similar quandary in the construction of your track layouts when laying the rails by hand.
To enhance the stability and operational reliability of the track, I incorporate a printed circuit board (PCB) sleeper approximately every eight standard sleepers. Such PCB sleepers prove particularly invaluable during the construction of switches. As you surely all know, the rails are soldered directly onto the board’s copper surface, thereby securing them at the precise gauge. However, a challenge arises: the lustrous copper finish and residual solder are so conspicuous that they invariably necessitate refinement.
I endeavored to impart a grain pattern to the threshold using a No. 11 blade and to harmonize its hue; yet, in comparison with genuine wooden sleepers, I remained dissatisfied with the outcome.
By chance, I still possessed strips of bass wood measuring 0.6 mm by 5 mm (1/32" by 0.2"), which I had originally intended for planking the plastic surfaces of my flatcars.
In accordance with the established procedure, grain simulation and chalk-based coloring, the wooden strips are affixed to the PCB using CA.
To better align the bass wood strips with the other sleepers, I gently rounded their edges with a blade and scored their ends….
…following a second coat of chalk of raw umber or sienna.
Nice job Jen.
Very nice tutorial. Thanks for taking the time to post. Looks great.
Thanks a lot, Curt and Travis.
I wasn’t sure if you were having similar problems, so I put together this really quick tutorial.
I appreciate you sharing your expertise with us!
