Dr. Grunge...The Dirt on Dirt...(Scenic Work and Sundries)
This thread was started in May, 2020
May 2020 in Scenery
I would like to thank Robert Burns for his motivation to get this thread to print. Thanks Bob.
Disclaimer: Uh, oh…the fine print already!..The following information is NOT how to do things…but how I do things. We all have our own styles of modeling based on our techniques, materials, skill level, etc. Example of this is how we can see a completed model and it becomes obvious who the modeler behind the model is! This is not necessarily a bad thing as long as we are happy with the results. However, should we find ourselves less than thrilled with the outcome, seeking additional resources comes into play. No matter your level of modeling we all can improve and tweak our processes. This is what I hope to accomplish here, to provide an additional resource. If I mention 25 “things” and someone comes away with one that helps them out…mission accomplished! On with the dirt on dirt…
May 2020
The format for this discussion will be the outside work on my current build, Scotia Supply. This accomplishes two major goals; firstly, actual scenic and scene construction is presented and…secondly, I get some needed motivation to get some work done on my build! We will forego talking about the research and planning that goes into our build and how it relates to our scenic work and scene construction. I will start with the diorama base and how I proceed from there.
With most any project the most important step is in the preparation. I use the green 3/4 inch dense foam board epoxied to 3/4 inch particle board (MDF I think it’s called?). The MDF is more resistant to warping than plywood. The 3/4 inch foam board provides an ideal surface for scene construction as you can vary the topography easily by cutting, sanding, poking holes, etc. and is paintable and does not absorb moisture.
If you remember one thing regarding scene construction and scenic work it would be…
LAYERING and TEXTURE…well two things I guess! This concept cannot be over emphasized. The creation of layering in your scene construction and the use of multiple textures is what creates realism. Moving on…after much pondering over the previous.
My first step is to prepare the diorama base for the first, and initial, layer of “dirt”. I use real dirt exclusively. Most would agree the only thing that looks most like dirt is dirt! Somewhat intuitive but worth mentioning. There are other products in use, and modelers have used it to good effect, but I stick with what I like and that’s good ole mother earth. Since I have so much verbiage here I now proceed with steps…
Step 1.
The first dirt layer I apply is a very fine layer that has been sieved to a very fine particle size, almost powdery. This base layer is the first in a series to build the layer effect. It also serves as a good base for pathways and road surfaces…more on that latter.
So I have my supply of sieved, first layer, dirt.
Step 2.
I then paint my diorama base with a flat latex paint, what color?..uhh…the color of dirt!
The first layer of dirt can be applied in one of two ways: Firstly, it can be applied directly over the wet paint. Secondly, it can be applied over the foam base after the paint has dried by applying a layer of diluted white glue with an old paint brush. I tend to use the latter as I think the dirt adheres a bit better with the glue. Once the paint/glue is dry the excess dirt can be removed. Now it gets interesting…Step 3 coming up…
May 2020
Gonna be a real treat to look over your shoulder. Your scenery is fabulous and I am eager to learn the techniques you employ. Like the original class tutorial from Karl this is information every modeler should possess!
May 2020
I had some paint mixed up once and when I picked it up I told the guy “it has a nice dirt look to it”. I think he was offended.
May 2020 edited May 2020
Thanks much Brett…
A shout out to Brett here regarding this thread. Brett addresses the issue of layering and texture most eloquently in his build manuals however, his main focus is on the structure build of his kits and the many beautiful scenes created by the plethora of castings and details provided in the kits.. It would be impractical to try and comprehensively address the many scenic techniques and applications. There are as many methods as there are modelers! The SWSM Manuals have all the necessary ingredients to create a beautiful diorama by following the advise and methods contained therein. Once again, this is just how I do it…
No doubt Bryan, how about the guy at Lowes when I actually brought in a small jar of the actual dirt and said “match this as best you can” Lol…
May 2020
Looking forward to this Ken, your scenery and scenes are always beautiful to look at and admire. Its going to be a real education to watch how you pull it all together.
I’m ready to learn a few new things and add them to my techniques.
Thanks for sharing your skills with us all.
I know…pictures, pictures…
Thanks for the encouragement Karl. You have paved the way for this thread and I remember how I struggled to get roads to look right until pouring over your techniques and how you and Brett preached about layering and texture.
Step 3.
The area I’m starting with is the north end of Scotia. Don’t be surprised that in an earlier post I may have called it the east side!..Lol.
Prior to knowing I was going to do this thread, I had begun the outside scenic work. Step 1 has been done as well as Step 2. In this scene I roughed in a dilapidated stairway to match the old bricked up doorway. I also spread my second application of ground work or aggregate. This is the beginning of the layering process. You will notice that right up against the foundation and out about an inch the material is more coarse then in the foreground. There is also a hint of a path from concrete steps out to the side drive.
Here is an expanded view of the scene we will be working on. The darker foreground area will be enclosed in a chain link fence as per Brett’s manual albeit expanded a bit. I now have a life time supply of wedding tulle! The reason for the darker area is this will be the kerosene and fuel oil depot of sorts…muddy and stained…that’s right…Grungy! Wheel ruts were done when the “ground” was still wet.
Back to the task at hand…the Step 3. aggregate…The material I use for this step has made a huge difference in my scenic work. Sometimes we stumble across a product or technique that seems to just work for us. This stuff is like that. Here’s how it went…
I struggled early on with getting the right aggregate to use for my second layering for the ground level. I tried coarser dirt, organic stuff, nothing spread well and looked right to me. Always remember, not everything prototypical looks good in 1:87!
Regressing a bit…I have a well used gravel driveway with a parking area at my cabin here in Ohio. The parking area has the smaller sized coarse gravel…say jellybean size. One day I was looking for a dropped nail while working on a project so my nose was right down at the ground level. While looking for the nail I notice the material between the coarse gravel was all ground up fine material of all sorts of stuff. I made a note and next trip brought my sieves. I sieved the material when it was nice and hot and dry. The fine material was simply wonderful! a natural mixture of minute rock grains, wood, leaves, etc…and little if any actual dirt. This stuff spreads great and has a very natural color and look and best of all varying texture. (see below)
Note the somewhat uniform color tones but varying textures and materials.
Recognizing a good thing when I see it…I sieved a large quantity and will have a life time supply by the looks of it!
So back to the scene. The material was spread along the foundation and sprinkled less as I came towards the drive. I spread a little on the drive, mainly in the middle and edges. Once this looked good, except for the driveway, path, and road (in background) I held a piece of paper up to the building and spritzed on some alcohol to break surface tension and then applied my white glue and water mix as standard. I applied mine by hand with a dropper…ie better control…more later
May 2020
Great info! Layering is very apparent. You didn’t give the address of your place in Ohio! :slight_smile:
May 2020
Great start Ken. It’s amazing what you can find around your house. I’ve collected a number of different size dirt and mini gravel. Also, it was Karl that got me to start with a base of dirt or grout over glue spread with a paint brush versus putting down a layer of dirt and digging out the pathways. Karl’s method and your method work so much better. Phil
Meanwhile, back at the dirt pile…
The next thing I do after the second layer of ground work is done is begin the scene composition. I like to scenic small areas at a time keeping in mind the overall concept of the diorama. In my example here, the north side of Scotia, is a little used area with an old blocked up doorway, dilapidated stairs, and an accumulation of basic junk.
This type of scene composition can be difficult to get started on. However, once you get in the grove of laying it all out things move quite quickly. I like to take pictures and research the web for junk scenes or any pictorial example pertaining to what I’m trying to achieve. Once I have in mind what I want to do, I begin to lay out the details in the rough positions as they will/may occur in the final scene work. Nothing is finished, nothing is glued down, just staged in a rough layout. I can change things around at will until I’m reasonably happy and then…
I take a few pictures. The main reason for the pictures is to allow me to put things back where they were after the details are prepared. Also, the pictures are on my phone and I can hash around the layout anywhere and make note on any changes to make once I’m back in front of the build.
Here is the picture I took of the North side of Scotia I have been working on. All is tentative but I’m beginning to get a feel that this is close to what I want. A few tweaks and details here and there to be added/changed. Note the layering of details and the use of many different details with colors and textures of a wide variety. Haphazard but things should still make sense.
Open barrel with a piece of corrugated on top, looks fine but for interest I added a couple of bricks and then put a pile of old bricks by the old stairs to tie in the concept. Also notice how some details are parallel to the building and some perpendicular. This is an important concept and adds visual interest. An old barrel laying on its side is a nice touch but putting a couple pieces of old wood of different size and color inside sticking out and the barrel laying partially on an old piece of corrugated adds even more.
So this is how I go about placing what I call hard details. As I’m planting the prepared hard details with glue I’m also working in the soft details, which are the various bushes, weeds, grasses, sedges, etc, also in layering fashion. Next up will be the placement and work on the soft details…more later…Ken
May 2020
We have the same way of working on details. I believe the most important fact is that it all has to make sense. There has to be a logic in the placement of things. There has to be a reason why details, castings are where they are..
There goes a lot of time in just making the composition before I glue anything down.
It just has to feel and look right.
That being said, thanks for presenting this subject .
May 2020
Such an important point. I’ve seen too many layouts where details were added for the sake of details. They don’t look right because of the haphazard placement. No logic. Thanks Ken for this wonderful tutorial.
Rick
May 2020
Great information Ken. I also try to place details so the make sense and look plausible. I like to have an assortment of details handy so I can play with their placement until I think they look right.
May 2020
This is indeed a ( another ) fun part of the job !!
May 2020
Ken, I’m with you so far. Great information. I’m looking forward to additional details. Thanks. Phil
ALCOALCO
May 2020
I finished the Foundry over the last week and was able to immediately apply some of Ken’s scenicking approach. Definitely upping my game! Thanks Ken
June 2020
I must apologize for the delay in posting here. There are several reasons , not the least of which, is that I’m a slow modeler. Another is that I’m in the process of building an entirely new modeling workshop. Anyway, here is an update…
Here’s where we left off. The north side of Scotia with the hard details staged to get a feel for the scene I’m looking for. This will be an older grown over area of discarded junk. I then set about detailing all these items in addition to adding the soft details of weeds, bushes, ground cover, etc..
Here is the nearly finished scene. Once again, layering the details and adding different textures but keeping in a fairly restricted general theme. The stark stone wall was softened with some climbing ivy. The barrel on the left was blended by having a bush placed behind and to the left so it didn’t appear to stand out. Same with the right edge of the broken stairs. This softens the hard lines and serves to blend it into the scene. Notice the difference between that barrel and the one beside the stairs…the one beside the stairs sticks out more and draws the eye to the stairs which will be more a focal point of the structure and highlights the traffic flow.
Close up of corner details. Note the crushed barrel with a piece of wood and debris sticking out to add interest. Pipe coming down the side of the building is a down spout. Right in front I pushed down the foam base to form a depression where the water would have eroded the ground a bit. A few large rocks and some water effects will complete the scene.
Next I will work on the front of Scotia with mostly hard details…more later…Ken
June 2020
Well worth the wait. Great modeling and superb explanation of how you create a very cohesive scene. Like an artist’s painting how you draw attention into the picture.
Rick
June 2020
A lot of really good info here..….love the way you blend it all together so that you can see it…and not really see it but “notice” it all at the same time. I love to look around in real locations and take photos to use for reference. If you want it to look real…mimic the real…Nice work Ken…
June 2020
Great update. Love the explanations. Phil
June 2020
Great scene! Textures, colors, materials and their placement blend so well. The different foliage textures and colors also make the scene cohesive. Thanks for sharing!
June 2020
did you head the barrel prior to crushing it?
June 2020
Appreciate that Rick. Hopefully there is some useful info. here.
Thanks Ed, still feel bad taking so long but once my shop is done things will be a little less hectic!
Thanks Muddy, photos of actual clutter scenes is a great way to build a diorama.
Hi Phil, thanks for checking in.
You bet Tom, thanks for your thoughts here.
Bryan, it’s a plastic barrel so I just squished it with my fingers.
Coors2u
June 2020
I always love the layering that you accomplish. Even down to the small pile of bricks. Everything also has a very natural look.
June 2020
please continue guru karnes…
patrick
June 2020
Very realistic look. Nice job!
June 2020
Would be nice to see the new workshop once you are finished. We will all probably get inspiration from it.
June 2020
Hah, NEW? From Ken. I am sure he will have a grungy and well weathered shop and yes, we better see some pics!
June 2020 edited June 2020
Nice hearing from you Dustin and appreciate your thoughts as always. Ever notice how once you start utilizing a certain detail, like the bricks, you can’t seem to complete a diorama without them!!Lol.
Thanks Kev, and glad you’re not bored yet!
Hey Patrick, appreciate that and for taking the time to check in.
Will do Tom, just got back from submitting my countertop measurements to the outfit that does that stuff. I will be utilizing a 9’ x 13’ room. Installed the short pile office style carpeting myself. Did some re-wiring to bring outlets up above the countertop…no hands and knees to plug stuff in! Re-purposed some cabinetry from another garage workshop. My space will not be much different than most other modeling workshops save for a few nifty things. As an example…when I model, build walls, weather wood, etc. I like to be sitting at my bench on stools. I, for some reason, don’t like to sit in a conventional chair to do my work. I prefer a stool without wheels that is a bit higher than a typical office chair. My current shop countertop is at 36 inches. I can sit on my stool, lean against it, or stand up to work…I like that.
Once I begin the diorama base, I like to stand up at a high countertop to work on it. That way I can freely move around, go get details, stand back and study it, etc…without having to get up and down from a chair. So…my main workbench at 36" high will be the full 13 feet wall-to-wall. It will have two separate workstations with a stool at each. Directly behind one workstation against the opposing wall will be a countertop and cabinet unit that I have modified to sit 40 inches high and 3 feet wide. This is where the current project diorama will sit allowing me to work on it standing up. There will be several other nifty additions as well…Sorry you mentioned my workshop?..Lol.
June 2020
Well what can I say Brett…Grungy is as Grungy does! Carpet is a multi colored dingy reddish brown ideal for loosing small parts, the walls are close to Reaper 29812 Meadow Green left over from another project, cabinets are from another garage shop, I installed the carpet myself (not an approved carpet installer), so yup, grungy it is but…the work that will come out of that shop will be even grungier!
June 2020
This Old Workshop by Ken Karns.
Brought to you by Sierra West Scale Models The most Award Winning Craftsman Kits.
The next Episode will be on where is the computer bench.
Stay Tuned.
June 2020
Ahh… thought about that. Have two Macs in the house with one in the basement where my shop is. It sits on my desk in a “home office” of sorts and I would miss it if I moved it into my shop. May look at getting an upgraded iPad for the shop as the one I have is ancient…
Well that’s one way to go Ed!
June 2020
I don’t know Ed, the way I work I’d have myself worked into a corner in no time.
November 2021
And a thread by Ken that I’m referencing for my RRC ‘dirt’ laying
November 2021
Great reference thread, might also call Ken “the Dirt Doc”?
November 2021 edited November 2021
How many bottles of the Reaper Meadow Green will you need to paint those walls?
November 2021
It is truly inspiring work. Excellent info, clearly presented.
Sakman
November 2021
LOL
