Railroad Camp : JimM
It’s been quite a long while since I did a build thread. Looking at all the fantastic thread on Brett’s forum has inspired me to start modeling again. I thought I’d take a shot at the railroad camp because it’s going to sit across from my Truck repair on the same Styrofoam base.
I’ve never tried modeling a masonry building and after looking at the fantastic resin casting, I thought I’d start there.
After minimal cleaning up to make sure I had a good fit, I epoxied the 4 wall together and then filled the gaps with a lightweight spackle.
I then primed the entire casting with the Kilz primer.
After that dried, I mixed up 5 colors of thinned paint and started painting the stones. To my chagrin, I think I thinned the paint a bit too much because it took quite a few coats to start seeing the colors.
I really liked how it turned out and then I took a picture. Yikes. To be honest it looks a lot better in person, the camera really washed out the color.
I started to add more coats and it’s gotten better but I’m still not satisfied how it looks to the camera.
I’m going to set this aside for a bit and concentrate on the upstairs office building.
I grained and stained the siding according the Galant method that we all know so well.
I decided to veer from the manual and give the office building a little color. I chose the blue that you see here because that’s what I had on hand.
I used Brett’s “damp brushing” technique, that I learned while doing my O’Neills project, to prepare the siding.
I also wanted the corner boards and the window trim to be a “vintage white” accent color because again, I had it on hand. Once again I used the damp brushing technique to get a peeling paint look.
When the siding dried, applied the corner boards along the scribed line, and then I started applying the siding paying attention to make sure the siding butted up to each other where the studs would be as scribed into the milled clapboard siding.
The windows are laser cut and they are “stained” with the same chalk/alcohol technique I used on the siding. I was very impressed at how well they stained. I then used a foam “q-tip” type applicator to “dry brush” the windows. I dip the applicator in paint, wring it out and then rolled it over the windows while still in the sheet.
Once dried, I started adding the window trim and the windows.
Here’s where I’ve left off.
Thanks for looking, more later.
Very well done, Jim. Sometimes the camera just does not want to cooperate. Your techniques look great. I really like the way a few of your windows are propped open. It gives the impression that the little people are there. I’ll be following along.
Larry
Thanks Larry, I appreciate you looking.
Yay! First brand new build thread on the new forum and it looks to be a very enjoyable build to follow.
The stone walls are amazing and were an unintended collaboration between Nick (minion) and Karl. The coloring looks great and yeah, those earthy tones can easily get washed out in photographs. Placing the blue office above and the two buildings to each side will totally change the appearance of the color values and tones.
Love the blue color on the clapboards and the peeling paint effect you achieved.
Can’t wait to see more!
Really neat Jim. Like the blue!
Thanks Brett, I have to say how impressed with the quality of these kits. When I think of all the work and the thought process that goes into making these kits, it boggles my mind. The templates, the jigs, the modeling techniques etc. Thanks for allowing us modelers to truly achieve a quality of diorama that wouldn’t be possible without your efforts.
Travis, thanks. The blue color is growing on me. We’ll see how it evolves through the process of building this kit.
Looks great, Jim. You’ve got off to a super start, and I really like the stone coloring on the masonry building. Looking forward to following your build.
You’re very kind to say that about my kits. Looking forward to more great updates!
Thanks George, I hope to have an update in another day or two. I’m glad you’ll be following the build.
Brett, I just calls em like I sees em. :grinning_face:
Not much of an update but I’ve got the warehouse walls finished.
Now trying to figure a way to blend in the resin freight door. Here it is just primed.
Jim, these walls look great as well. Know how much work you put into them to get that tone just right.
Thanks Travis, appreciate it.
Nice graining, saw banding, (toothpick?) knots, great color variation! You’ve got it all!
Thanks so much Al, I’m enjoying this kit a lot. I appreciate you taking the time to comment.
Here’s a quick mockup of the structures so far. No weathering as yet.
Looks good Jim. Like what you did on the freight door. Looks very natural.
Great work here Jim! Blue is a color not often modeled but lends itself well. Your paint peel is terrific. The stone work looks great, you might try a dark wash to highlight the individual stones. Railroad Camp is a kit I have been just waiting to build. Such an iconic work. Look forward to seeing your progress as you work through this project. Well done.
This is fantastic. I love where this is going and cannot wait to see more. The color and weathering is spot on. Thanks for sharing!
Thanks Travis, I’m happy with the freight doors as well.
Ken, I appreciate your advice. I’m not entirely finished with the stone work. It looks much better in hand, the camera seems to wash out the color. I will do another dark wash for sure. Probably also add some color to some of the stones as well.
Thanks Brett, I’m looking forward to advancing further with this fun kit.
Nice work Jim! I like the color of the wood on the warehouse. Nice idea to have the doors and windows a weathered white. It adds a lot. This was one of my favorite kits to build. I built it several years ago. So much variety in the structures. I concur with Ken a wash on the stone will highlight things more.
