The stack of boxes at the foot of the dock stairs isn’t touching the ground. That’s a nit considering the high quality of your detail work and overall weathering! Great job!
Nice work Curt! This really turned out nice! You should be proud of what you have completed. The scenery is well done as is the rest of the build. Looking forward to your next build.
Great work Curt and a joy to follow your build. Thanks for sharing along the way.
Good Morning All,
Terry thank you, you are very kind.
swissrail thank you and I will follow your suggestion in future builds.
Ken thank you for your kind words and following along with this amateur.
Alco thank you and I see it now. I guess I need to improve my sanding skills.
tommich thank you for your kind words and following along.
Travis thank you so much for your kind words and following along
Curt, i see you put all those people to work. Nicely done.
Great job finishing up BlueSky. You did an awesome job and should be very proud of the finished diorama. The MACK Bulldog is the perfect addition.
Ray thank you for your kind words and following along.
Brett thank you for the high praise from the master.
Really nice work. I love all the little details and the people really make it come alive. My only suggestion would be to be careful that the casting are buried or lay flat on the decking. The realism is challenged when you can see gaps under the castings. Overall great work.
Joel thank you for the great suggestions about the detail parts. I need to be more aware of that.
