Another O Scale Sawmill! :Bill
This thread was started in November 2017
November 2017 edited November 2017 in O Scale Builds
After not posting a construction thread for way too long I’m jumping back in, but I’m venturing out into unfamiliar territory: O scale! I’ve watched Karl, Joel, and others construct amazing models with stunning details that I felt were beyond my reach in HO. Add the legendary CHB machinery along with my love of logging and the O scale sawmill kit was an obvious choice for my next project.
IMG_0218
I actually began building it in March of last year. I’ve been researching sawmills, stockpiling pictures, and collecting larger scale techniques and ideas for even longer. I knew I wanted to include a water feature in the diorama and that would require some considerable changes to the original model. (One change has a habit of altering 4 or 5 elements down the line!) All that being said, I need to thank Brett right off the bat. He helped me work through numerous obstacles and hurdles that I created while trying to incorporate my ideas. Also Karl, Ken, Alan and Joel have shared their insights and second opinions when my self-doubt would get the best of me. You guys are some of the most talented modelers in the hobby and I can’t thank you enough for chiming in when the call went out!
This won’t be a typical step-by-step construction thread for a couple reasons…
  1. The O scale mill has been well documented here on the forum
  2. I lost a ton of pictures when my camera’s memory card crashed. Bummer!
I’ll try to stitch together the pictures and document the build as best as I can. I’ve been experimenting along the way and I’ll be sharing some pretty cool and useful techniques that worked well for me. So, here we go.
Not that it stays this way for very long, but THIS is what my workshop looks like when it’s clean:
The footprint for my version is 4 feet x 2 1/2 feet. The log pond will be situated in the upper right in the next picture. The mill subfloor is complete at this stage and stands on a large collection of weathered piers. It’s test fit on the diorama base along with an initial layer of dirt (sanded tile grout).
Next update, we’ll take a look at the log haul machinery (which isn’t part of the current kit #308).
November 2017
Bill looks like you have gotten a great start. I’ll be following along.
Don’t know if you still have it or if you’ve already tried this but you might Google “photo card recovery”. You might have some luck (which you could then share with the rest of us). :slight_smile:
November 2017
So glad to see you posting this build Bill. What a treat we are in for to follow along with your brilliant work on the SWSM O Scale Sawmill. Anyone who had the privilege of seeing Bill’s work on this piece at the EXPO can attest to the shear magnitude of this kit and the stellar detail and finish Bill has imparted. Such a great design and the execution is stunning and it’s far from complete…I’m all in on following this one my friend!
November 2017
I am looking forward to seeing how you achieved such stunning results. Following along for sure.
November 2017
The same for me !
November 2017
Looking forward to following along
November 2017
This will be a lot of fun to watch Bill bring it all together!
Great hearing from all of you and I appreciate the encouragement!
MikeM–as far as the lost pictures, I took the card straight to a local camera shop. I was using a ProMaster Compact Flash memory card (the kind that newspaper photographers use). My camera shop has some specialized software and tools to extract files that would otherwise be lost. No luck. Unfortunately, when a card like this is “guaranteed for life” and it fails…all that means is they give you a new card–not the missing pictures!
Such is life!
By including the log pond and log haul, I changed the mill’s order of operations. As explained in the manual, the raw timber was brought by rail to the mill and unloaded onto the rollway skid. In my model, the logs are delivered up the green chain from the pond. So I changed a major function of the rail service: Rather than delivering fresh cut trees, the trains would now haul away the rough sawn boards (product lumber). That involved moving the rails to the opposite side of the mill. At this stage of construction, that was an easy change achieved with a Sharpie!
Here comes the real work…
One of the first orders of business was to adapt the Log Deck and log haul to fit the structure. These two features are not part of the O scale kit. They were a couple of items that, I believe, Brett acquired along with the rest of the CHB line. So, my version will look completely different than the original rollway (pictured on pge. 26-29 of the O scale manual):
Mine is at an angle and has 4 rails that the logs roll down. The supporting frame also needed to be condensed and allow for correct alignment with the log carriage, carriage drive, and structural elements of the mill itself. After bouncing some ideas off Brett, here’s the configuration that resulted:
In looking at the last photo, the supports have kind of a “hodge podge” appearance (that’s because…well, it WAS!). However, the majority of the framework that supports the skidway will be hidden by a walkway that will give the workers a way to get from place to place . Also, you can see that there’s nothing supporting the log haul machinery. That gets added later (after I determined the height of the log haul, the depth of the log pond, and changes that needed to be made to the shoreline).
The log haul machinery is unbelievable! (In fact, the same can be said for ALL the castings and machines in the kit). The level of detail is stunning and I wanted to take full advantage of all of it. I mentioned in my Deer Creek mine build that I was experimenting with mineral spirits and chalk (rather than alcohol and chalk) on some of the metal castings. The mineral spirits can give a softer transition from weathered vs. unweathered areas. I went that route again on the log haul: the sections of the spokes show more rust near the hub as opposed to the areas toward the wheel. It seemed to me that there’s a lot of metal-on-metal contact in that area, plus it gives the gears a little contrast and definition.
After that, I added grease build-up and oil stains using dark chalk (raw umber 408.3 and some straight black in a couple spots) and MIG “Fresh Engine Oil.” I’ll go deeper into this process later in the build.
Here’s how it looks connected to the sub-floor:
I realize that I’m bouncing around quite a bit and I’m documenting my progress using some lousy pictures. But hopefully, it’ll make more sense as we progress. Any questions that I can answer… fire away!
I’m going to get deeper into the machinery construction in the next update.
November 2017
Looking great Bill, your attention and your ability to see (and model) things so often over looked has always set your work apart. Looking forward to more from you on this one.
November 2017
Good job getting graining on the dowels. That’s never easy.
November 2017
Bill that is some excellent work and thanks for the tutorial.
Will be interesting on how you did the grease and oil stains.
November 2017
Karl-
Much appreciated and glad to have you along. Your original build provided a lot of inspiration and answers as I went along.
Jerry-
Thanks for the kind words. I’ll get into the oil & grease very shortly.
Bryan-
I referred to your model many times as well! Texturing the dowels can tear up more than a few wire brushes, for sure. To get some really deep grain and texture, I tore into them with a nail board. I clustered up a bunch of finishing nails leaving the points exposed and then give the dowels several back n forth passes:
November 2017
This is the same technique Canyon Creek Scenics uses to make their trees and logs.
November 2017
Bill, I will be following this build aswell, so I can profit from your expertise when I build mine.:slight_smile: Thanks for posting.
Robert
November 2017
Great progress and attention to detail as always Bill. Machinery finish is top notch.
November 2017
I too will keep and eye on this…as I stopped my sawmill build to do the O’Neills kit. I am also doing a log pond…and got stuck on figuring out the modifications to include it on the main building. I already had the log haul kit…so…I’m watching Bill…
November 2017
Thanks for the comments and for following along everybody.
MikeM–that’s probably where I got the nail board idea. Pete Vassler does some amazing work!
The machinery in the O scale sawmill is as close to art as you can get. The accuracy and detail are stunning. The boiler and steam engine provide power to the husk saw, log carriage, live rolls and log turner, and also the cut off saw and edger. Assembly of all these items is nothing difficult. However, the parts are identified right off of the machinist’s drawings. If you’re not familiar with working from mechanical drawings (like me!) it’s not a bad idea to label and organize all the components.
For example, on a two dimensional drawing, a front pressure roll and a rear pressure roll look pretty similar (parts 6 & 7). But when laid out and identified, there’s a major difference between them:
I found that it was time well spent to count, separate, and identify by number EVERY part for each machine. Again, assembly was straight forward once I was familiar with what goes where.
I wanted to “dirty up” certain machines and components to give them an appearance of being in service for many years. This picture shows what I was going for: the accumulation of grease, oil and grime around the moving parts and different surfaces. Some places have what looks like fresh, leaking oil; other spots have a build-up of “gunk” and grease:
Using the log haul, here’s a basic step-by-step of how I got my results. The “Oil & Fuel weathering set” from Ammo by Mig Jimenez has 3 different types of oil and grease stains and works great. You can get this set on amazon or a hobby shop:
I began by applying small splotches of “Engine Grime” (a grayish satin-sheen oil residue) to the areas around the pillow blocks:
While the engine grime is still wet, I added a really light layer of chalk (raw umber 408.3). By “light layer” I don’t mean the amount of chalk, but the size of the particles. Rather than a blade to shave off some chalk dust, I used a small make-up brush to create a “cloud” of chalk powder (the idea is to get the chalk so fine that it almost looks like a puff of smoke):
I let this cloud of chalk build up so that it soaks up the wet paint. This first layer has a grayish color and a flat finish. You can (hopefully) see where the chalk has accumulated on top of the pillow blocks:
Next, I repeat the process but this time I use “Fuel Stains”. This paint is a clear brownish-black and has a glossy finish when dry. I add tiny drops of the paint on top of the patches just created, on top of the pillow blocks, and around the line shafts where they stick out of the pillow blocks. I follow that with a “cloud” of chalk, let it settle onto and absorb the wet paint:
For the vertical oil drips, I used the same “Fuel Stains” applied with a really tiny brush. Rather than paint them in freestyle, I use a machinist’s square and rest the brush against it. That way the drips will be perfectly straight up and down and parallel to the others:
Another application of “Fuel Stains” and chalk but this time a little lighter in color (408.5 and 408.7). The lighter chalk adds some definition and is a nice contrast to the previous layer–which will look almost black. The repeated applications help create the illusion of that fuzzy film of grease:
Once I got to a point where I liked the look, I let everything dry overnight and reevaluated the next day. For the most part, once completely dry, it looks a lot like the last picture above–sort of damp and grimy. Once it was 100% dry, I went back and added a few tiny drops of the Fuel Stains here and there so that there were some fresh oil spots.
The final step is to take and rub a #2 pencil over the teeth of the gears so that they shine a bright silver from the repeated metal on metal contact.
Here are a few shots from both sides of the haul mechanism. Terrible lighting on the first two, but here are a few close ups of the effect:
MarkG
November 2017
Very nice Bill. Gives me a lot to look forward to. I really appreciate the subtle touch on your details. I know it would be a bear, but there would be wear on the vertical surfaces of the gear teeth at least on the driven edges, at least from my experience in real life.
Keep up the fine art!
Mark
November 2017
Thanks Mark. You’ve got me curious about the areas that should show more wear.
Do you mean on the sides of the gear and gear teeth? Like here:
MarkG
November 2017
Bill I think you’ve done that really well. As the gears engage, the inside edges of the teeth where one tooth bears against the surface on the other sprocket will tend to polish each other. So not the external sides of the sprockets, but the interior bearing surfaces of the teeth, like caring pencil burnishing down onto the bearing surfaces of the sprocket teeth.
Does that make sense?
Mark
I gotcha now. Yeah, that makes sense. The crazy thing is I thought that they looked too shiny and new so…I intentionally mucked 'em up. I went and added the grease and gunk in between the teeth, kind of like you see on a roller coaster lift chain and sprocket:
November 2017
Bill most excellent. And thanks for the tutorial.
November 2017
Very nice job on the gunk accumulation. That is very difficult to get just right without overdoing it.
Great work Bill real nice and spot on. I tried to buy on the mig paint web site and the login has me at a dead end can you help me out …Carl
November 2017
Bill I am all set. …Carl
November 2017
The photos explain a lot! Thanks and very neat work indeed.
November 2017
You can find a set of these on Amazon. You can also Google “mig engine fuel oil” or “ammo military model paint sets”. I’d love to see if some of these colors could be added to a second set offered by Brett.
November 2017
You can find the paint set on eBay, too. The one I use is MIG 7402. I’d avoid the other sets. There are some that only include 1 jar of paint along with 2 jars of pigment (powdered chalk).
Mike-
I had talked to Brett about getting these included with the SW paints. The issue is that the SW paints are acrylic and the Mig stuff is enamel.
One of the most important machines in the mill is the double blade husk saw. I recall Brett had some great language describing the saw in Twin Mills manual. He called it a “beast” and a “monster” and with one look, you KNEW “this thing was wicked”. Man, I love that sentiment! I wanted to make sure that statement came through on my model.
In my research, I learned a lot about these beasts:
*the blades were pretty massive (6-8 feet in diameter was not uncommon)
*they generated a lot of heat when cutting and were usually cooled with water
*when in use, they look reflective and shiny
On the other hand…this dude hasn’t seen action in years:
I began by blackening all the metal components and polished up the ones that needed to look shiny (the surfaces of the drive wheels) with a felt buffing pad and this little Dremel polishing wheel:
The frame and supporting structure I left black and again added a layer of “shop gunk” just like on the log haul. This time, I used a couple shades of raw umber chalk along with a blackish-brown enamel wash (Mig “Track Wash”) and the fuel stains paint (for the wet, oily areas).
Same process as before: dampen the piece with Track Wash; let a cloud of chalk snow down on the area and absorb the enamel paint. I repeat this process using less and less paint and more and more chalk until it’s built up to a fuzzy layer.
Try as I might, I couldn’t color and weather the paper saw blades to convey that ferocity described above. So, I went on the hunt for real metal blades and found these at Harbor Freight:
The lettering was removed by spinning the blades in my Dremel and scratching it off. I think I used everything from sandpaper to emory boards and files and even an old sharpening stone. That also helped scribe in wear marks and deep scratches:
Two issues with using these little hobby blades:
First, the holes in the center were too big for the blade hub on the model. So, using a paper punch and some heavy aluminum foil I punched out some circular filler pieces and added one to the hole in the blade. Then, I poked a hole in the center of the foil so that the blade arbor shaft could stick through. Attach the blade nut to the shaft and issue #1 was solved!
The second issue was the size of the hobby blades. Using the biggest one was out of the question. Way too big. Using two of the second biggest baldes was close:
…yet so far away:
So, I opted to model mine like the double blade saw pictured above: a large blade on the bottom and a smaller blade on top. Not perfect, but a plausible solution.
Here’s the saw positioned in the mill:
I also wanted to model that greasy work area that you can kind of see in the double blade picture above (near the feet of the guy with the green shirt). I measured and cut some floor planks for the spot where the operator stands. I did my thing with Fresh Oil paint and 408.3 chalk but built it up only on the sides closest to the saw. That way, it would look like the water and oil pooled right at the base of the machine.
It takes repeated applications of straight up Fuel Stains paint in order for it to stay wet looking. It would keep getting soaked up by the chalk, I guess. But eventually, I got a couple wet looking oil spots on top of the “shop gunk”. It’s in an area that’s tough to photograph, but here’s a shot of it today:
November 2017
Great job on the blades Bill. And your weathering technique is sure working out well.
Your work is amazing and your tutorials are the best! This is what modeling here is all about! If you don’t get motivated and excited to do some bench work modeling after perusing Bill’s posts…well…there’s no hope for ya!! Well done my friend…
November 2017
Thanks Jerry-- hope you’ll try these ideas out.
Ken–very kind of you to say and much appreciated! Your post motivated ME to get off the
inter-tube and keep building.
November 2017
Your digital prowess is much more suited for modeling than inter-tube wandering!
November 2017
Ken–especially when I leave my laptop in a hotel in Altoona, PA.
Ed–Thank you! I hope you’ll try it out and report back with your results.
November 2017
Sure looks like the real thing.
November 2017
The detail in that last picture is fantastic…from the oil and grease buildup to the perfectly placed sawdust. Just awesome man…
Alan
November 2017
My sawmill is sitting started on a shelf in the shop…O’Neills is sitting dormant on the workbench…your outstanding work got me to go down to the shop last night and get going again so I too can get back to the sawmill…Keep up the outstanding work!
December 2017
Bill thanks so much for taking the time to share your techniques. You have such a fantastic eye and get such realistic results. I love to learn and learning from the best is what this forum is all about. Kudos!!
December 2017 edited December 2017
Thank you for all the positive comments, guys. Your words are both flattering and motivating at the same time. Hopefully, you’ll try out some of these ideas and get similar results.
This update will finish up the major machinery contained within the mill (the log turner and log haul ramp will come later). This is another area where I’m missing a lot of the pictures documenting the construction process. Fortunately, most of the weathering I added to these items followed the methods I outlined in the log haul entry.
Let’s start with the large horizontal boiler. For complete steps on construction, take a look at how I built the HO boiler in the “Deer Creek Mine” build:
Official HO Scale Deer Creek Mine Forum Build : Bill - Official Build Threads - SierraWest Scale Models Forum
Again, I used white chalk on the areas that get exposed to extreme heat and black chalk over the areas that don’t get as hot (like at the seams and edges). I also took care to shape the intricate piping so the bends were crisp and at the correct angle, position the valves in line and true, and to install the tiny gages in a straight line protruding the same height.
For the planer, I used craft paint to color the frame. I love Karl’s suggestion of Apple Barrel “Christmas Green”. When first applied, I looks really LOUD. But by simply handling and rubbing the pieces, the color will get darker and wear off in spots. To get this effect, use the paint straight without thinning it down.
Also, I used Bryan’s idea of having the individual boards exiting the machine while a full piece is going into it:
The Sawmill Project kit #308: brownbr - O Scale Builds - SierraWest Scale Models Forum
I cut slits into the full piece making sure they were in line with the blades. The cuts were made far enough into the board so that the piece butted up against the large rollers (red arrow). With the individual boards, I sanded them down on one end so they were really thin. Those ends were tucked under the large rollers and below the full sized piece of wood. The transition between the two is almost invisible:
Here’s the log carriage. Straight forward construction with more outstanding detail:
Finally, the twin cylinder steam engine. I LOVE this piece! It was colored using “Christmas Green” as before, then dulled down with raw umber chalks. The valves got a light dusting of gold ochre chalk to give them a bronze appearance. Fuel stains were added using the Mig enamels and the heavy grease around the large wheel was done with the same process described earlier, however I’m pretty sure I used black chalk to “soak up” the oil.
If I failed to explain something or if my explanations aren’t clear, ask away!
There’s more to come…
December 2017
Simply outstanding! The boards on the edger look perfect. My favorite is the coloration on the cylinders…
December 2017
Bill you are in the modeling groove my man…brilliantly done! My favorite is the last picture of the log carriage…that “clutch” mechanism detail is for a lack of a more appropriate term…perfect! Combination of colors and detail is wonderful.
December 2017
Thanks much, gents!
Brett–the Christmas Green works like a charm and leaving a couple areas plain metal color adds a nice accent.
Ken–two of the levers are a bright yellow craft paint that I mixed chalk into (some raw umber) just to see how it’d work. The one selector piece was done with a regular red that I rubbed and dusted with raw umber.
December 2017
Great coloring. The board going through the edger doesn’t get any better.
Fine work all around.
December 2017
So much to comment on. Just love it. I particularly like the variation in colouring on the metal parts of the log carriage and the chipped paint on the levers. That’s not to say the engine and boiler and edger aren’t fantastic. What a great eye for colour and texture.
December 2017
Bill The best as always every time…Carl
December 2017
Looks great Bill, the worn green on the machinery, rust etc.
December 2017
It is looking so good! The subtle grease buildup around the wheel on the engine is an example of what is making the whole presentation look so realistic. Looks like your maintenance man set his oiler down on top of your cylinder also.
I was looking at some pics of steam donkeys recently. It looked like there was a lot of “gunk” build up around the piston inside the cylinder also.
December 2017
Bill, this is POETRY for the eyes. Fantastic man. I am keeping all of your photos in a special map to use as documentation when I start mine. Thanks for posting all these.
December 2017
Great stuff here Bill. All the machines look really great. The wear and grease build up is perfect. Great work all around.
October 2018
Bill what happened to the rest of the build???
January 2019
Bill still waiting??? Oh an Happy New Year!!
January 2019
Sorry Jerry. I’m still around and I’ve made a lot of progress (it’s about 85-90% complete).
I just realized it’s been a year since I updated this entry!
I’ve been heavily focused on some issues with work, but that’s coming to an end hopefully within a week or two. Once I’ve got that finalized, I can put my focus on important stuff—this being priority #1!
January 2019
i’m grateful this thread was reactivated. bill, your machinery looks like the absolute 1:1 real deal. if i didn’t know i was looking at your model, i would completely be convinced they were the authentic real life machines. it’s just amazing. awesome.
January 2019
Thanks Bill. Will be looking forward to you getting backon this one.
January 2019
Bill, I’m going saw milling myself pretty soon. Guess who I will use as my guide? Man, I love your work! You are the Chuck Doan of 1/48th scale. Our mill engines are very different, but yours REALLY helped me understand how to do mine. Thanks again, saw mill buddy.
January 2019
Bill, where have you been? I’ve missed you on the forum. Of course, I’m constantly referring to your mine build. It’s bee a great help. Phil
Mario
February 2019
wow… great photos…and workmanship…
April 2019
Okay Bill its now close to Easter!! That’s April how’s the focus on work doing I bet its 85-90% complete!!
Bet you think I’m a PITA well I am!!
April 2019
this here is some truly amazing modeling. i love this forum…
May 2019
Okay Bill April showers has brought May flowers!! What has happened at the Sawmill??
October 2019
Summer is over! The leaves are falling timber will be cut soon.
Is the mill ready for the next haul of logs??
October 2019
We are curious !!!
October 2019
we had a frost last night. good thing i got the gardens out last weekend.
Pennman
November 2019
Bill,
I’ve been out of the hobby for quite some time, but do look on here occasionally. I can’t agree more with all of the comments before me, you are the Man!! Excellent modeling and colorization on machinery and wood coloring. Amazing modeling.
November 2019
Sorry to hear that Bill. The hobby needs people not people leaving!!
Best of luck in whatever you do.
